T.M.02-06-2005, 03:53 AM
Try the relearn procedure first.
In step 7,the tool there refering to is a large magnet.I used the one off my dial indicator.
Programming TPM Sensors
Important: Make sure the vehicle has been stationary for at least 2 minutes before attempting to program the TPM sensors.
1.Turn the ignition to ON.
2.Press the RESET button in order to clear any IPC display warning messages.
3.Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
4.Press and hold the DIC RESET button for 3 seconds.
5.Press the OPTIONS button again until the TIRE TRAINING message appears. Notice: If the TIRE TRAINING message cannot be displayed, and the IPC is functioning properly, check if the BCM is configured with the correct RPO codes. Refer to BCM Programming/RPO Configuration.
6.Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
7.Install the J 41760 Tire Pressure Programming Tool over the left front valve stem.
8.The horn will sound, indicating the left front TPM sensor is programmed. Notice: If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool. This procedure may have to be attempted up to three times in some instances.
9.When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
LEARN R FRONT TIRE
LEARN R REAR TIRE
LEARN L REAR TIRE
Programming Cancellation
The programming mode will be canceled if any of the following conditions are met:
The program mode is exited through the DIC.
The ignition is turned to OFF.
All four sensors have been programmed.
The TPM system has been in the program mode for longer than 2 minutes and no sensors have been learned.
If the program mode is canceled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
Copyright © 2005 ALLDATA LLC
Diese Tool J 41760 ist ein Rundmagnet oder Kernmagnet,sieht auf jeden Fall aus wie eine dicke Unterlegscheibe.
Gruß Molle
Werner
