03.04.2014, 00:13
		@@ Jef
Der Filter hat ein sehr feines Sieb was höheren Öldruck verhindert
Die Papierfilter lassen höheren Öldruck zu
Powerfilter Oil Filters utilize two piece billet style precision machined housings and bases made of aircraft quality aluminum. The filter element itself is a finely woven 45 micron stainless steel mesh that is easily removed and can be washed clean and reused. We do offer replacement elements in case your original one becomes damaged or is otherwise in need of replacement. Additionally, extra fine elements are available for racing applications. Due to the extreme fine mesh used (10 microns) in the racing elements, these should not be used on the street. Should be cleaned after each race event.
Mfg Jörg
Mfg Jörg
