	Themen: 23
Niederlande
Baureihe:
C6
Baujahr,Farbe:
2005 Precision Red
		Folgendes steht im Service Manual, ich glaube es gibt kein Schalter:
Automatic Transmission
The underhood fuse block supplies battery voltage through the STOP/B/U/ LPS fuse to the coil and switch terminals of the BCK/UP LAMP Relay located in the body control module (BCM). When the transmission is placed in the REVERSE position, the transmission control module (TCM) sends a class 2 message to the BCM. The message indicates that the gear selector is in the REVERSE position. The BCM grounds the back up lamp relay control circuit of the reverse lamp relay. This energizes the reverse lamp relay, closing the switch side contacts and provides battery voltage to the REVERSE LAMPS fuse through to the backup lamps. The backup lamps are permanently grounded at G302. With both power and ground the backup lamps illuminate. Once the driver moves the gear selector out of the REVERSE position, a message is sent by the TCM via class 2 serial data requesting the BCM to remove ground from the REVERSE LAMP Relay control circuit. This opens the REVERSE LAMP Relay switch contacts turning OFF the backup lamps.
Callaway Honker
Ported throttle body
Ported intake
Crane Cams 1.8 ratio rockers
Kooks Jet Hot coated headers
Callaway Competition Shocks
Hotchkis sway bars
Diablosport Trinity with custom tune
Brian Tooley Racing valve spring kit
	Themen: 285
		Der Rückfahrschalter liegt beim "Schalter" direkt unter der Schaltkulisse.
Gruß Chris
