22.06.2013, 14:45
		Hallo liebe Artgenossen,
ich würde gerne Vinyl Reparatur Produkte bestellen, im Katalog (Corvette America) finde ich folgende Produkte:
1 Interior Dyes Corvette America’s Interior Dye
produces accurate color and solid coverage on
leather, vinyl, fiberglass, plastic and metal. Available
in a 12-oz. Aerosol spray or Quart. Use your
interior Color Code to complete the part number.
2 Dye Surface Prep Use our Surface Prep to remove
dirt, oils and residue before priming. Fast drying
and ready to paint in minutes.
3 Adhesive Promoter Promotes strong, even
adhesion of topcoat material when repairing or refinishing plastics.
Also works on most flexible or rigid plastics on painted surfaces.
4 Primer For best results, finish off your prep work with our quality
primer. Promotes even paint coverage and a better finish.
5 Spray Adhesive Our high-tack Interior Spray Adhesive is easy to work
with and produces a strong bond between hardparts & materials.
6 Interior Dye Clear Coat Protect your reconditioning work for years to
come with our Interior Clear Coat. Covers your interior components
with a smooth, protective finish & preserves your interior’s color.
Ich habe ehrlich gesagt nicht genau verstanden was zur Reparatur benötigt wird, ich nehme an
1), 3) und 4), liege ich da richtig?
Thank U und viele Grüße aus dem verregneten München
Dirk
Dirk
Schnucke
![[Bild: sig_edgar.jpg]](https://www.reitz-net.de/bilder/sig_edgar.jpg)
