25.05.2003, 09:58
HI, Well I check the drive shaft and the Front u-joint has some play... The rear one seems ok and the Transimisison yoke doesn't have ANY play. I was told a New drive shaft with u-joints and transmission slip yoke costs around $200.00... I think I'm going to go that route. Also my passenger side rear wheel bearing is shot. I just replaced it 5 months ago.. OH WELL... I'm going to replace the drive shaft, the wheel bearing and see if that fixes the problem.
I also indexed the drive shaft.......
Please write in english
